Chrome users: This site IS secure!
The HUMMER Network Forums
Log In... Log In... Log In......
Post new topic   Reply to topic    The Hummer Network Index -> Forum-Related Questions
crank
PostPosted: Sun Apr 27, 2014 11:15 pm    Post subject: Log In... Log In... Log In...... Reply with quote
Has anyone else have problems logging in to the forum and staying signed in?
Every time I go to the website, it wants me to log in again.
I check the box to remember me, but no good. I use a iPad. Maybe that's it?
1997 Yellow H1 6.5L TD HMCS Wagon - "HANK" (H)ummer t(ANK).
2006 Yellow H2 LUX
2013 Harley Davidson Tri-Glide
******* MADE IN MORDOR *******
WB2HUQ
Patriot Guard Riders
HOG Member
__________
l T |[___|___]
[---T--L -OlllllllO-]
()_)"()_)/"**"\)_)
"I CAN EXPLAIN IT TO YOU, BUT I CAN'T UNDERSTAND IT FOR YOU"!
CRANKIT!
View user's profile Send private message
forum mgmt
Custodian
PostPosted: Mon Apr 28, 2014 12:59 am    Post subject: Re: Log In... Log In... Log In...... Reply with quote
This is the place for forum-related questions.
Check the cookie settings in your browser. It sounds like it's set to delete cookies after the session or when the browser is closed. Cookies are used to keep users logged in automatically.
This is covered in the Help section:
http://www.hummernetworkforums.....p?t=195194
crank
PostPosted: Mon Apr 28, 2014 1:41 am    Post subject: Re: Log In... Log In... Log In...... Reply with quote
Thanks forumadmin.
My bad. I wasn't too sure where it was to go.
I'll check the cookies on my iPad. Not too sure how that's done, but I will check into it.
Thanks for the information also.
2006 Yellow H2 LUX
WB2HUQ
HOG Member
__________
l T |[___|___]
()_)"()_)/"**"\)_)
CRANKIT!
forum mgmt
Custodian
PostPosted: Mon Apr 28, 2014 1:47 am    Post subject: Reply with quote
My iPad logs me in automatically each time.
Go to Settings and find Safari in the column on the left. Under "Block Cookies", make sure it's not set to "Always". Mine is set to "From third parties and advertisers".
Thanks.
crank
PostPosted: Mon Apr 28, 2014 2:06 am    Post subject: Reply with quote
Mine is also set to third parties and advertiser.
My iPad had always logged in automatically. Just recently it wouldn't log in.
Maybe the new update did it.
Thanks
Thanks.
2006 Yellow H2 LUX
WB2HUQ
HOG Member
__________
l T |[___|___]
()_)"()_)/"**"\)_)
CRANKIT!
forum mgmt
Custodian
PostPosted: Mon Apr 28, 2014 2:18 am    Post subject: Reply with quote
I just updated mine to IOS 7.1.1. Auto-login works just fine
Look for anything else that might be blocking cookies. I don't know if there are firewalls for iPads, but if you have one check that or any kind of malware/adware blocker. Otherwise you may need to find an Apple or iPad support forum.
forum mgmt
Custodian
PostPosted: Mon Apr 28, 2014 2:54 am    Post subject: Reply with quote
I may have found it!
You might have private browsing enabled. Tap the + sign in the upper right corner of Safari. Then click on "Private" in the lower left corner. If it's on, you'll get the option to turn it off. If it's off, you'll get the option to turn it on.
When I turned on private browsing, I went to the forum and was not logged in. When I turned private browsing back off, I went to the forum and was logged in.
Check that. It's the only way I've been able to reproduce the problem.
See:
http://support.apple.com/kb/HT.....cale=en_US
crank
PostPosted: Mon Apr 28, 2014 3:38 pm    Post subject: Reply with quote
YOU DA MAN!
It started working ok once I changed the "Private" button.
Thanks
2006 Yellow H2 LUX
WB2HUQ
HOG Member
__________
l T |[___|___]
()_)"()_)/"**"\)_)
CRANKIT!
brunsyeah
PostPosted: Mon Apr 28, 2014 8:45 pm    Post subject: Reply with quote
Good to know. I had the same issue but only occasionally? Weird I know but now I know the answer!
Thanks
2000 H1 Wagon
6.5td
View user's profile Send private message Send e-mail
Post new topic   Reply to topic    The Hummer Network Index -> Forum-Related Questions All times are GMT
