View previous topic :: View next topic |
Author |
Message |
gunshow8 Sarcastic forum member in training
Posted: Fri Feb 07, 2014 12:51 am Post subject: Trouble uploading pictures with IPhone |
I'm using an IPhone 5 which is running 7.0.4 OS software and I cannot upload pictures to the forum.
Anybody know why or having the same issue? _________________ 2001 Black on Tan HMCS
2018 Colorado ZR2 |
Back to top |
E55 Bulldog Lead Driver
Joined: 28 Jan 2010 Posts: 1642 Location: Wilmington, NC
Posted: Fri Feb 07, 2014 1:04 am Post subject: |
I'm having the same issue but I have a 4s. For some reason now my image files are no longer JPEG and are coming through as something else _________________ 1997 HMC4
2001 HMCS - Sold
2004 HMCO - Sold
2001 HMCS - Sold |
Back to top |
Posted: Fri Feb 07, 2014 1:28 am Post subject: |
Weird thing is that I use to be able to upload pics just fine when I was running the older OS software.
I checked all my security settings and everything. I should be ok?? Help _________________ 2001 Black on Tan HMCS
2018 Colorado ZR2 |
Back to top |
forum mgmt Custodian
Posted: Fri Feb 07, 2014 1:31 am Post subject: |
Please note that there is a place for forum-related questions. It's not the H1 forum.
This is covered in the Help section:
http://www.hummernetworkforums.....p?t=232006
It should work with IOS 7 and above. It not, you may need to seek iPhone assistance.
What happens when you attempt to upload attachments? Is the option grayed out? Can you provide more information to go on? |
Back to top |
Posted: Fri Feb 07, 2014 1:37 am Post subject: |
I'm in the same boat. Had no problems in the past but how I have to email them to my computer and convert them to JPEG before I can upload from my lap top. _________________ 1997 HMC4
2001 HMCS - Sold
2004 HMCO - Sold
2001 HMCS - Sold |
Back to top |
Posted: Fri Feb 07, 2014 1:43 am Post subject: |
I just tried it with my iPad using IOS 7.0.4. I could choose a photo to upload, but when I hit the "add attachment" button, the keyboard wants to pop up. Same when I hit the "Preview" button. Neither button will work.
Is this what is happening to others?
Something must have changed with the most recent update of the OS. It did work OK before. Someone should check with Apple support. This is not a forum issue. |
Back to top |
Hummer Network Since 1996
Joined: 31 Jul 2006 Posts: 8759 Location: Location, Location
Posted: Fri Feb 07, 2014 2:11 am Post subject: |
I've posted the question on the Apple support board. If/when I receive a response, I'll post it here.
A little Googling turns up lots and lots of bugs with IOS 7.0.4. It looks like IOS 7.1 is in beta right now. _________________ Serving the Hummer community since 1996 |
Back to top |
Posted: Fri Feb 07, 2014 3:01 am Post subject: |
When I hit CHOOSE FILE I get 3 options
Take Photo or Video
Choose Existing
Cancel
I hit CHOOSE EXISTING and it takes me to my photos. When I choose a photo it places the photo into the attachment file name line which says 1 photo.
Then I click add attachment, then the screen says :
Technical Description:
504 Gateway Time-Out The Web server is not responding _________________ 2001 Black on Tan HMCS
2018 Colorado ZR2 |
Back to top |
Posted: Fri Feb 07, 2014 3:45 am Post subject: |
This issue may or may not be resolved with the next version of IOS. It's only occurred since IOS 7.0.4 came out. In the meantime, while a solution is being sought, you'll have to e-mail photos to yourself and upload them using a computer.
I found one way around it. There are apps available which turn your iPhone/iPad into a remote control for your computer. I have a free one called TeamViewer. I can take a photo with my iPad, e-mail it to myself, link the iPad to my computer and use that to upload the photo to the forum. That way, you can do it even if you're away from your computer at the time. _________________ Serving the Hummer community since 1996 |
Back to top |
Jesse7159 Lead Driver
Joined: 29 Apr 2013 Posts: 2993 Location: Portland, Oregon
Posted: Sat Feb 08, 2014 10:28 am Post subject: |
I have the same problem. I'm a Member on a different forum (cummins forum) and can upload pics fine _________________ 2000 open top. Gloss black. 4" body lift. Optimizer long block. Full chassis restoration. Custom all black interior with all plastics coated in Line-x. HMMWV poly body mounts.
Stazworks 20" wheels with 395/85r20 Michelin XZL's
Blue hummer: SS brake/MC lines, half shaft locking kits, spindle locking kits.
Icentropy: spring spacers, full dash bezels, dash grommets, shift knobs, idler locking kit, custom HVAC relocation.
Hummer dan RPP step version. |
Back to top |
Posted: Sat Feb 08, 2014 4:58 pm Post subject: |
It appears something changed in the way IOS 7.0.4 uploads files which is incompatible with this particular forum software. I have some feelers out to some experts to see if there's a way to compensate on this end.
In the meantime, I will offer a free photo uploading service. If you have a photo taken with an iPhone or iPad which you want to add to a forum post, e-mail it to:
HummerNetwork@gmail.com
and I will personally upload the photo(s) to your post. You should be the author of the post, not me, so post it yourself and send me the photo(s). I can add the photo(s) to the post after the fact. I'll even adjust the photo orientation if necessary.
I will post this offer on the H1 forum shortly. Hopefully this will only be a temporary workaround. _________________ Serving the Hummer community since 1996 |
Back to top |
Posted: Wed Feb 12, 2014 6:31 pm Post subject: |
A possible solution is being explored. _________________ Serving the Hummer community since 1996 |
Back to top |
